Home> Products> Switches > Access Switches>
RG-S2900G-E V3 Series Switches
Ruijie RG-S2900G-E V3 Series is a collection of next-gen multiservice switches, offering remarkable performance and enhanced security,switch delivers non-blocking, wire speed switching performance. Implementing an industry-leading hardware design and Ruijie’s latest RGOS11.X modular operating system, the switches offer better table capacity, improved hardware processing performance, and easier user operation.
More+
●Industry-leading CPU protection mechanism: The CPU Protect Policy (CPP) provides policies for protecting the CPU of a switch. In network environments, various attack packets spread, which may cause high CPU usages of the switches, affect protocol running and even difficulty in switch management. To this end, switch CPUs must be protected, that is, traffic control and priority-based processing must be performed for various incoming packets to ensure the processing capabilities of the switch CPUs.
○CPP can effectively prevent malicious attacks in the network and provide a clean environment for legitimate protocol packets.
○CPP is enabled by default. It provides protection during the entire operation of switches.
○Denial of Service (DoS) attacks may consume lots of memory, entries, or other resources of a switch, which will cause system service termination.
○Massive attack traffic is directed to the CPU, occupying the entire bandwidth of the CPU. In this case, normal protocol traffic and management traffic cannot be processed by the CPU, causing protocol flapping or management failure. The forwarding in the data plane will also be affected and the entire network will become abnormal.
NFPP Network Protection
●Easy management: Administrators can centrally manage all the devices at the same time. It is no longer necessary to configure and manage the switches one by one.
RG-SNC Topology Management
Design For Durability
Conformal coating: Conformal coating is a special formula coating, coated on the surface of PCBA board, cured into a layer of about 100um thick transparent protective film, conformal coating has excellent insulation, moisture, dust, Anti-corrosion, anti-mildew, anti-salt spray performance.
Conformal coating Protection
RG-S2928G-E V3
RG-S2952G-E V3
24 10/100/1000BASE-T ports
4 1G SFP ports (non-combo)
48 10/100/1000BASE-T ports
Fan Slots
Fixed
Management Ports
Up to 256Gbps
Up to 96Mpps
Up to 132Mpps
Up to 16K
Routing Entries
IP Host Entries
(IPv4/IPv6)
Up to 1,500
AP, LACP, Flow balance,802.3ad
Up to 128
IGMP v1/v2 snooping, IGMP SGVL/IVGL, IGMP filter, IGMP fast leave
MAC, EEE, ARP, VLAN, Basic QinQ, Felix QinQ, Link aggregation, Mirroring, STP, RSTP, MSTP, Broadcast storm control, IGMP v1/v2 snooping, IGMP SGVL/IVGL, IGMP filter, IGMP fast leave, DHCP, Jumbo frame, RLDP, LLDP, REUP, G.8032 ERPS, Layer 2 protocol tunnel
Layer 3 Features
Layer 3 Protocols (IPv4)
Static routing, RIPng, OSPFv3
Support (Up to 4 stack members)
RAS
VSU (virtualization technology for virtualizing multiple devices into 1); GR for RIP/OSP;  ERPS (G.8032); REUP dual-link fast switching technology; RLDP (Rapid Link Detection Protocol)
(W x D x H) (mm)
440 × 260 × 43.6
≤3.5kg
≤4kg
>200K hours
Lightning Protection
6KV
Frequency: 50 to 60Hz
≤24W
≤40W
Storage humidity: 5% to 95%RH
IEC 60950-1,EN60950-1
Emission Standards
The RG-S2900-E/P V3 gigabit secure and intelligent access switches are ideal for the following and scenarios alike
●Full gigabit access to LANs of large-scale enterprises and institutions, such as government buildings, large manufacturing, energy, and metallurgy enterprises Full gigabit access to server clusters
●Secure access through flexible and diverse security control policies that can defend and control network viruses and attacks
●Full gigabit access to business systems, such as hospitals, libraries, exhibition centers, and websites
This networking topology enables RG-S2900-E V3 series to cooperate with convergence switches (eg.RG-S5750-H) in an entire building and core switches (eg.RG-N18000 series) in the core area to provide gigabit services for desktops. The 10G high-bandwidth links converge in the core area to satisfy user requirements for increasing information volumes in universities, libraries, laboratories, financial centers, offices, and exhibition centers.
RG-S2928G-E V3
RG-S2952G-E V3
  • Sales Enquiry
