Home> Products> Switches > Access Switches>
RG-S2910-H High Power over Ethernet (HPoE) Switch Series
The HPoE switch is highly adaptive to a breadth of scenarios, eliminating rigid ties to expensive deployment costs, slow implementation cycle, unstable power supply, management complexity, and unsatisfactory security problems that alternative solutions have been struggling to solve. The switch fully addresses high PoE access needs for low power scenario as well as high power Wi-Fi hotspot application in outdoor venue. Industrial-grade Power Box (PBOX) is available to support non-PoE appliance or non-IEEE 802.3bt powered device (PD). The PBOX fully supports remote power supply for high power devices.
●Up to 60 Watts per Port by High-power PoE Technology (IEEE 802.3bt)
●Industrial-grade PBOX for Flexible Remote Deployment (12VDC/ 24VAC Options)
●Outstanding Power Supply Stability (Average Error Rate <0.5%)
●Time & Cost Saving on Construction Works
More+
HPoE
HPoE
Simple Deployment
Shortened construction period
Reduced costs
Simple Deployment
Secure and Reliable
Easy O&M
Device Security
In tough environments with thunderstorms and electromagnetic interference, devices are prone to damages caused by strong transient currents.
HPoE provides multiple protection mechanisms;
Overcurrent protection, preventing device damages even upon short circuits;
Up to 6KV port lightning protection, ensuring stable operation in various tough environments.
In independent deployment mode, strong-current cables are used in most cases. The voltage of power cables is higher than the safe voltage limit (36 V), and may cause accidents.
The HPoE technology complies with international power supply standards and features a low voltage and high safety, ensuring safety of O&M and working personnel.
Network Security
Support for various types of ACL, port security, and IP + MAC + Port binding technologies, effectively preventing various ARP frauds
Proactive prevention against DoS and DDoS attacks
Support for the CPU Protect Policy (CPP) and Network Foundation Protection Policy (NFPP), effectively preventing attacks against standalone devices and the entire network
Network Security
Stable and Reliable Power Supply
High-power (60 W) and long-distance (100 m) power supply is provided. Compared with the conventional centralized power supply mode:
The HPoE technology complies with international standards; adjusts line loss and lowers voltage intelligently, reducing errors caused by manual adjustment; and provides independent power supply over single ports, achieving faulty domain isolation.
Quick and Easy to Build
No Power Cable Required in Scenarios with Network Cables
To supply electricity to high-power STAs (> 30 W), an independent power supply system needs to be deployed, and the resulted grooving, pipeline layout, wire-threading, debugging, and wall and floor embellishment cause highly complex construction and a long construction period.
Only the network cable is required for power supply and data transmission via HPoE.
Reduced Cost & Less Investment
30% Cost Off in Typical Configuration Mode
If an independent power supply system is deployed, materials such as the power chassis, power cables, power socket, and power adapters are required, while a construction fee will also be incurred, resulting in high overall fees.
In HPoE power supply mode, the previously mentioned materials and accessories are not required, which reduces overall fees by 30% in typical deployment scenarios.
8路50密网络电源部署合计对比图
Remote Restart for Easy O&M
In conventional power supply mode, the power supply system is not connected to the network. When a device is faulty, its power supply must be located for a manual restart, which can rapidly resolve most problems. However, if the power supply of the faulty device cannot be restarted due to environmental restrictions, other more complex solutions need to be adopted.
HPoE enables the power supply system to be connected to the network. Consequently, a faulty device can be remotely restarted using a PC to rectify faults rapidly and improve O&M efficiency.
远程重启 轻松运维
The VSU technology virtualizes multiple physical devices into one logical device and uses a single IP address, Telnet process, and CLI for management.
Multiple devices are managed as one device, ensuring high management efficiency.
On-Demand Service Management and Control
  • Scheduled power-on/off of STAs:
    The STA power-on/off time can be customized based on user habits.
  • Uninterrupted power supply during hot start:
    Power supply to STAs is not interrupted during restart of the HPoE power supply host.
  • Power status check at any time:
HPoE Switches
RG-S2910-24GT4SFP-UP-H
RG-S2910-24GT4XS-UP-H
RG-S2910-10GT2SFP-UP-H
Up to 256Gbps
Up to 256Gbps
Up to 256Gbps
Up to 96Mpps
Up to 96Mpps
Up to 18Mpps
16K
64 (IPv4/IPv6)
In: 1500
Out: 500
In: 1500
Out: 500
In: 750
Out: N/A
Basic QinQ, Flexible QinQ
OpenFlow
VSU Stack Members
Up to 9 stack members
VSL
MAC, VLAN, Basic QinQ, Felix QinQ, Mirroring, STP, RSTP, MSTP, Broadcast storm control, IGMP v1/v2 snooping, IGMP filter, IGMP fast leave, Jumbo frame, RLDP, LLDP, REUP, G.8032
IEEE802.1d, IEEE802.1w, IEEE802.1s, IGMP Snooping v1/v2
Layer 3 Features
ARP, IPv4/v6
IPv4 Routing Protocols
Static Routing, RIP
Static Routing, RIPng
802.1p/DSCP traffic classification; Multiple queue scheduling mechanisms, such as SP, WRR, DRR, SP+WRR, SP+DRR; Input / output port-based speed limit; Each port supports 8 queue priorities
802.1p/DSCP traffic classification; Multiple queue scheduling mechanisms, such as SP, WRR, DRR, SP+WRR, SP+DRR; Input port-based speed limit; Each port supports 8 queue priorities
GR for RIP
GR for RIP
GR for RIP
Dimensions (W x D x H) (mm)
440×260×44
440×260×44
340×260×44
>200K hours
Lightning Protection
6KV
6KV
6KV
Frequency: 50Hz to 60Hz
RG-PBOX-DC12: Support 12VDC output and 10/100/1000M Ethernet signal transmission
RG-PBOX-AC24: Support 24VAC output and 10/100/1000M Ethernet signal transmission
(*For detailed specifications of the adapters, please refer to the below table.)
<460W
<460W
<870W
PoE Power Consumption
Total 760W PoE/PoE+/HPoE budget output power
Storage humidity: 5% to 95%RH
Industrial Adapters
RG-PBOX-DC12
RG-PBOX-AC24
Product Description
High-power PoE power adapter, supports 12VDC output and 10/100/1000M Ethernet signal transmission, suitable for indoor or semi-open spaces.
High-power PoE power adapter, supports 24VAC output and 10/100/1000M Ethernet signal transmission, suitable for indoor or semi-open spaces.
2 10M/100M/1000M Ethernet ports, 1 standard power supply terminal block
Power Input
Input voltage range: 43-57V DC
Input Interface: RJ45
Maximum input power: 80W (PBOX input)
Power Output
Power output port, 12VDC/60W
Power output port, 24VAC/60W
-20℃ to 50℃
-40℃ to 70℃
10% to 90% (non-condensing)
10% to 95% (non-condensing)
-500m to 5000m
Protection Rating
IP40
187x89x35
With its powerful and flexible high-power PoE feature, the HPoE Series can fully meet the network requirements of the following scenarios:
  • The PoE remote power supply of the high-power devices in different systems of a smart building, such as surveillance system, access control system, information broadcasting system, digital clock system, parking system, etc.
  • In a variety of outdoor wireless deployment scenarios, the HPoE Series can meet the power supply requirement of the high-power outdoor wireless APs.
Scenario
The HPoE Series provides high-power PoE remote power supply for the infrared dome cameras of the smart building, access control card reader, parking entrance gate, information broadcasting device, etc.
RG-S2910-H Deployment for Smart Building
The HPoE series, as the power supply of the IP devices, supports an immediate power-on of the devices once connected to the network.
RG-S2910-H Powering the End Devices
Values:
●Compared to the existing power supply method using power cables, the HPoE Series can significantly reduce equipment cost and implementation cost.
●High-voltage power cables are used in the existing deployment which has a certain risk. On the other side, the low-voltage power supply of HPoE is safe and reliable.
●All devices can be accessed by the network via IP deployment and can be integrated with the IPDM (IP Devices Management) system for unified remote control.
RG-PBOX-DC12
Support 12VDC output and 10/100/1000M Ethernet signal transmission; suitable for indoor or semi-open space
RG-PBOX-AC24
Support 24VAC output and 10/100/1000M Ethernet signal transmission; suitable for indoor or semi-open space
  • Sales Enquiry
