Home> Products> Switches > Access Switches>
RG-S2910XS-E Switch Series
Ruijie RG-S2910XS-E is a collection of next-gen Gigabit switches architected for superior security, high performance and outstanding energy efficiency. The series delivers full Gigabit access and unparalleled scalability to 10G performance. With the all-new hardware architecture and Ruijie’s latest RGOS11.X modular operating system, the RG-S2910XS-E switches offer larger table capacity, faster hardware processing performance and a better operation experience than anything previous. In addition, the PoE models in various specifications support all downlink ports running on PoE+ and fulfill high bandwidth demand of 10G uplink. The RG-S2910XS-E switches guarantee high-density user access and leading aggregation performance with ease.
●Network Virtualization (VSU) Support
●Dynamic Network Protection (CPP and NFPP Technologies)
●Basic Layer 3 Routing Support
●Power Redundancy Support
●Full 48-Port PoE+ Support
More+
Diverse ports
Secure and Reliable Hardware
and Software
Strict component selection
3-month reliability testing
Accurate traffic statistics
Compared with the RG-S5750-S products with the same configuration, the S2910XS-E reduces power consumption by more than 40%.
Compared with the RG-S2900G-E products with lower configuration, the S2910XS-E reduces power consumption by about 10%.
Flexible Port Types and
On-Demand Expansion
Multi-Process and Modular
OS RGOS 11.X
Optimal Quality
Stable Device Running,
PoE models, On-Demand Service
Management and Control
VSU Technology
Easy management:
Millisecond failover:
Exceptional scalability:
Fans with Multi-level Smart
Speed Adjustment
Always Seeking Ways to Boost
Optimization
RG-S2910-24GT4XS-E
RG-S2910-48GT4XS-E
RG-S2910-10GT2SFP-P-E
RG-S2910C-24GT2XS-P-E
RG-S2910C-24GT2XS-HP-E
RG-S2910C-48GT2XS-HP-E
24 10/100/1000BASE-T ports
48 10/100/1000BASE-T ports
10 10/100/1000BASE-T ports
Expansion Slots
Modular Power Slots
Fan Slots
Fixed
Fixed
Fixed
Fixed
Fixed
M2910-01XS
M2910-01XT
M2910-02XS
M2910-04XS*
M2910-02XT*
M2910-01XS
M2910-01XT
M2910-04XS*
M2910-01XS
M2910-01XT
M2910-04XS*
Management Ports
1 USB 2.0 port
1 USB 2.0 port
264Gbps
264Gbps
256Gbps
264Gbps
264Gbps
264Gbps
96Mpps
132Mpps
18Mpps
96Mpps
96Mpps
132Mpps
Max. Number of 10GE Ports
16K
Routing Table Size
(IPv4/IPv6)
64 (IPv4/IPv6)
In: 1,500
Out: 500
In: 1,500
Out: 500
In: 750
Out: N/A
In: 1,500
Out: 500
In: 1,500
Out: 500
In: 1,500
Out: 500
Basic QinQ, Flexible QinQ, 1:1 VLAN switching, N:1 VLAN switching*, 1:N VLAN switching*
AP, LACP (maximum 8 ports can be aggregated* ), Cross devices AP, Flow balance
IEEE802.1d STP, IEEE802.1w RSTP, Standard 802.1s MSTP, Port fast, BPDU filter, BPDU guard, TC guard, TC protection, ROOT guard
128
OpenFlow 1.0 & 1.3
Support (up to 9 stack members*), Local and distant stacking, Cross-chassis link aggregation in the stack, Stacking via 10G Ethernet ports
SCN (Simplicity Campus Network)
Support establishing large L2 network with core devices and achieve resources pooling via VSU and VSD. Only management on core devices is required and hence simplifies horizontal and vertical network management and maintenance.
Layer 3 Features
IPv4 static routing,RIP, IPv6 static routing, RIPng
Layer 3 Protocols (IPv4)
Static routing, RIP
Static routing, RIPng
Standard/Extended/Expert ACL, Extended MAC ACL, ACL 80, IPv6 ACL, ACL logging, ACL counter, ACL remark, Global ACL, ACL redirect, Time-based ACL
802.1p/DSCP/TOS traffic classification; Multiple queue scheduling mechanisms, such as SP, WRR, DRR, SP+WFQ, SP+WRR, SP+DRR; Input / output port-based speed limit; Port-based traffic recognition; Each port supports 8 queue priorities; flow-based rate limiting with the minimum granularity of 8Kbps
Binding of the IP address, MAC address, and port address; Binding of the IPv6, MAC address, and port address; Filter illegal MAC addresses; Port-based and MAC-based 802.1x; MAB; Portal and Portal 2.0 authentication; ARP-check; DAI; Restriction on the rate of ARP packets; Gateway anti-ARP spoofing; Broadcast suppression; Hierarchical management by administrators and password protection; RADIUS and TACACS+;Change of Authorization;AAA security authentication (IPv4/IPv6) in device login management; SSH and SSH V2.0; BPDU guard; IP source guard; CPP, NFPP; Port protection
SNMPv1/v2c/v3, CLI (Telnet / Console), RMON (1, 2, 3, 9), SSH, Syslog / Debug, NTP / SNTP, FTP, TFTP, Web, SFLOW
Hot Patch
Smart Power Supply
(W x D x H)  (mm)
440 × 260 × 43.6
440 × 260 × 43.6
340 × 260 × 44
440 × 260 × 44
440 × 320 × 44
440 × 360 × 44
≤3.5kg
≤4kg
<2.5kg
5.8kg (gross weight)
6.8kg (gross weight)
>200K hours
Lightning Protection
4KV
4KV
6KV
6KV
6KV
6KV
Frequency: 50/60Hz
Rated current: 1.5A
Frequency: 50/60Hz
Rated current: 1.5A
Frequency: 50/60Hz
Rated current: 2A
Frequency: 50/60Hz
Rated current: 6A
AC power (RG-M5000E-AC500P):
Frequency: 50/60Hz
DC power (RG-M5000E-DC500P):
Rated current: 16.5A
AC power (RG-RG-PA1150P-F):
Frequency: 50/60Hz
Rated current: 10A
Rated current range: 10A
Frequency: 50/60Hz
Frequency: 50/60Hz
Rated current: 10A
24W
50W
470W (with full PoE)
850W (with 24-port PoE+)
1700W (with 48-port PoE+)
PoE Power
125W
370W
RG-M5000E-AC500P: 370W
RG-M5000E-DC500P: 370W
RG-PA1150P-F: 740W
RG-PA1150P-F: 740W
Storage humidity: 5% to 95%RH
 *Future release support
The RG-S2910XS-E switch series features high security, efficiency and intelligence with superior energy-saving capacity. The series is suitable for the following scenarios:
●Full gigabit access to LANs of large-scale enterprises and institutions, such as government buildings, universities and large manufacturing/ energy/ metallurgy enterprises
●Full gigabit access to business systems, such as hospitals, libraries, exhibition centers and websites
●IP phones, WLAN access points and high-definition cameras access
●Full gigabit access to server clusters and 10G high-bandwidth uplink
●Secure access through flexible and diverse security control policies that can defend against network viruses and attacks
Scenario 1
The RG-S2910XS-E Series Switch is deployed with the RG-S5750E/P Series / the RG-S78E Series Aggregation Switches. Also teaming up the RG-N18K Series at the core, the deployment provides Gigabit Ethernet downlinks and 10 Gigabit Ethernet uplinks to meet the ever-increasing number of network nodes and demanding bandwidth requirements.
Scenario 2
The RG-S2910XS-E Series Switch can be deployed with RG-S78E Series/ RG-S86E Series/ RG-N18K Series to provide Gigabit Ethernet downlinks and 10 Gigabit Ethernet uplinks to the simplified core network architecture. Different combinations provide comprehensive coverage for network deployment of large, medium and small sizes. Not only does it simplify the network architecture, but also significantly enhances the stability and efficiency of the network system.
RG-S2910-24GT4XS-E
RG-S2910-48GT4XS-E
24 10/100/1000BASE-T Ports (PoE/PoE+), 2 100/1000BASE-X SFP Ports (combo), 2 1G/10GBASE-X SFP+ Ports (non-combo), 1 Expansion Slot, AC
Optional Accessories
M2910-01XS
M2910-01XT
M2910-02XS
*M2910-02XT
* Planned for future support
*M2910-04XS
RG-M5000E-DC500P
FE-SFP-LX-MM1310
100M Multimode Interface Module (2km)
FE-SFP-LH15-SM1310
100M Single-mode Interface Module (15km)
Case Study
More >
  • Sales Enquiry
