Home> Products> Switches > Core Switches>
RG-S7808C Core Switch
Ruijie RG-S7808C Core Switch is specially designed for next-gen integrated network. Implementing advanced RGOS11.X operating system and VSU/VSD virtualization technologies, the switch future supports future Ethernet requirements. The leading technologies break customer physical network barriers to form an integrated network. The VSU (Virtual Switch Unit) feature greatly simplifies customer network architecture to enhance the operational efficiency. The VSD (Virtual Switch Device), another virtualization technology, significantly lowers the total cost of investment by improving device utilization. The RG-S7808C switch is ideal for MAN, campus network and settings alike.
Feature highlights of RG-S7808C Core Switch:
●Cost-effective Entry-level Chassis Switch
●Superior Performance with up to 81.48Tbps Switching Capacity
●Support Network Virtualization (VSU & VSD) and Advanced Layer 3 Routing (OSPF, BGP)
●Carrier-class Reliability: Control Engine/ Power/ Fan Redundancy, Hot-swappable Components
●Support Large-scale MAC (up to 64K) and ARP Table (up to 20K)
●Support PoE/ PoE+ with Independent PoE Power Supply Module
More+
Virtualization for Demand-based Allocation
Virtual Switch Unit 3.0 (VSU)
The RG-S7808C switch supports the Virtual Switch Unit 3.0 (VSU). The technology can virtualize 2 devices into one logical unit, which largely minimizes the number of network nodes and reduce maintenance workload. Superior 50~200ms link failover ensures smooth and uninterrupted transmission of key services. The RG-S7808C switch supports cross-device link aggregation for easy double uplink to server/switch, effectively maximizing bandwidth investment return.
Virtual Switch Device (VSD)
The RG-S7808C switch supports VSD in which one device can be virtualized into multiple virtual units. Each virtual unit has a unique configuration management interface and independent hardware allocation (e.g. storage, TCAM and hardware forwarding table). All the features support restart with no impact on other virtual machines. Users can realize network resource allocation based on different needs. Resources of the core switch can hence be shared with other domains and users. With the enablement of both VSU3.0 and VSD, the switch satisfactorily delivers complete resource pooling.
Redundant design of the RG-S7808C switch key components delivers excellent protection: control engine power and fan modules all support 1+1 redundancy. All redundant components are hot-swappable to maximize reliability and availability. Hot patch and ISSU technologies are also supported to enable online upgrade.
Support GR for OSPF/IS-IS/BGP and BFD for VRRP/OSPF/BGP4/ISIS/ISISv6/static routing to enable the fast fault detection mechanism of different protocols. The feature minimizes the fault detection time to less than 50ms.
Since 1998, Ruijie has been investing on the R&D of modular operating system. The RG-S7808C software platform is designed based on the next-generation RGOS 11.X multi-processing modular operating system to integrate the service features such as loosely coupled firewall, wireless and authentication into a unified cloud network operating system. The RG-S7808C software platform also supports full virtualization and offers rich data center and campus network features. The key availability indicators such as multi-processing modules, process backup and hot patch have reached the industry-leading level.
Excellent Energy Efficiency
The internal system is designed for low voltage power supply with high-efficiency modular power to form a more efficient power supply system. The multi-core CPU supports dynamic power management with all Ethernet copper ports implements the Energy-Efficient Ethernet (EEE) standard to save power under light load.
The smart fan supports 256 speed modulations with precise temperature control, energy saving and noise control. The device can function at high temperature for a long period of time or in harsh environment. The RG-S7808C switch thereby helps clients to maximize savings on air conditioning.
RG-S7808C
Module Slots
8 (2 for control engines)
Modular Power Slots
15.36Tbps/81.48Tbps
624Mpps
Max. Number of 10GE Ports
Up to 48
Up to 20K
Up to 64K
Routing Entries
Up to 10K
Multicast Entries (IPv4/IPv6)
Up to 8K/4K
Up to 3,500
Up to 4K
Basic QinQ, Flexible QinQ
AP, LACP
Many-to-one mirroring, One-to-many mirroring, Flow-based mirroring, SPAN, RSPAN, VLAN mirroring
Support STP, RSTP and MSTP
64 (not include default 0)
Up to 2,048
Up to 1,000
Up to 2 stack members
Up to 4 VSD units
Jumbo Frame, 802.1Q, STP, RSTP, MSTP, Super VLAN, GVRP, QinQ, Flexible QinQ, LLDP, ERPS (G.8032)
IEEE802.1D (STP), IEEE802.1w (RSTP), IEEE802.1s (MSTP), IGMP Snooping, Jumbo Frame (9Kbytes), IEEE802.1ad (QinQ and flexible QinQ), GVRP
Layer 3 Features
ARP, IPv4/v6, PBR v4/v6
Layer 3 Protocols (IPv4)
Ping, Traceroute, Equal-Cost Multi-Path Routing (ECMP)
Static routing, RIP, OSPF, BGP4, ISIS, VRRP, Equal-cost routing, Policy-based routing, GRE tunnel
Static routing OSPFv3, BGP4+, IS-ISv6, MLD, VRRPv3, Equal-cost routing
Policy-based routing, Manual tunnel, Auto tunnel, ISATAP tunnel, GRE tunnel
DNS client v6, DHCP relay v6, DHCP v6 server, Telnet v6, TFTP client v6, FTP v6, NTP client v6, NTP server v6
Routing Protocols
IPv6 Tunnel Features
6over4 Manual Tunnel, 6to4 Auto Tunnel, Manual Tunnel, Auto Tunnel, ISATAP Tunnel, IPv4 over IPv6 Tunnel, IPv6 over IPv4 Tunnel, GRE Tunnel(4 over 6), GRE Tunnel(6 over 4)
IGMP v1/v2/v3, IGMP snooping, IGMP proxy, Multicast routing protocols (PIM-DM, PIM-SM, PIM-SSM), MLD, Multicast static routing
ACE Capacity
Up to 3,500
802.1p, Queue scheduling mechanisms (SP, WRR, DRR, WFQ, SP+WFQ, SP+WRR, SP+DRR), RED/WRED, Input/output port-based speed limit
Control engine, power supply and fan: 1+1 redundancy; Hot-swappable components; Hot patch and online patch upgrade; GR for OSPF/IS-IS/BGP; BFD for VRRP/OSPF/BGP4/ISIS/ISISv6/static routing
Support EEE (802.3az)
NFPP (Network Foundation Protection Policy), CPP (CPU Protection), DAI, Port Security, IP Source Guard, 802.1x, Portal authentication, RADIUS and TACACS+ user login authentication, uRPF, Account privileges and password security policy, Unknown multicasts are not delivered to CPU and support unknown unicasts suppression, Support SSHv2 to provide a secure and encrypted channel for user login
Hot Patch
Smart Power Supply
(W x D x H)
442mm ×595mm ×439mm, 10U
10RU
32.35kg
312K hours
IEC 60950-1, EN 60950-1
Emission Standards
RG-PA1600I-F:90-180V~1200W;180-264V~ 1600W
RG-PA600I-F:90-180V~ 600W;180-264V~ 600W
RG-PA1600I-PL:90-175V~1000W;176-264V~1600W
RG-PA3000I-PL:90-175V~1200W;176-209V~2500W;210-264V~ :3000W
<176W
PoE Power Consumption
<800W
3,000m to 4,000m
RG-S7808C Main Chassis & Control Engine
S7808C
8-slot Chassis with 2 fans (without power supply)
M7800C-CM
S7800C Control Engine
  1. Power Supply and Fan
Select at least 1 power module according to the power supply requirement of the device.
RG-PA600I-F
S7800C Power Module (support redundancy, AC, 600W, 12V)
RG-PA1600I-F
S7800C Power Module (support redundancy, AC, 1600W, 12V)
RG-PA1600I-PL
S7800C PoE Power Module (support redundancy, AC, 1600W, 16A)
RG-PA3000I-PL
S7800C PoE Power Module (support redundancy, AC, 3000W, 16A)
M78-PSE
S7800C PoE Box, for RG-PA1600I-PL and RG-PA3000I-PL
M08-FAN
S7800C Fan, each consists of 2 fan units and 1 fan control board, support side-to-rear airflow (included by default)
  1. Line Card & Service Module
Select the host line cards according to your real application.
Commercial Line Card
M7800C-16SFP8XS-EA
Line Card with 16 Gigabit Ethernet fiber ports (SFP, LC), 8 10G Ethernet fiber ports (SFP+, LC)
M7800C-24SFP/12GT4XS-EA
Line Card with 24 Gigabit Ethernet fiber ports (SFP, LC), 12 Gigabit Ethernet copper combo ports (RJ45), 4 10G Ethernet fiber ports (SFP+, LC)
M7800C-36GT12SFP4XS-EA
Line Card with 36 Gigabit Ethernet copper ports (RJ45), 12 Gigabit Ethernet fiber ports (SFP, LC), 4 10G Ethernet fiber ports (SFP+, LC)
M7800C-48SFP4XS-EA
Line Card with 48 Gigabit Ethernet fiber ports (SFP, LC), 4 10G Ethernet fiber ports (SFP+, LC)
M7800C-48GT4XS-EA
Line Card with 48 Gigabit Ethernet copper ports (RJ45), 4 10G Ethernet fiber ports (SFP+, LC)
M7800C-48GT4XS-P-EA
Line Card with 48 Gigabit Ethernet copper ports (RJ45), 4 10G Ethernet fiber ports (SFP+, LC), support PoE/PoE+
  1. Transceiver and Cable
10GBASE-SR, SFP+ Transceiver (300m)
10GBASE-LR, SFP+ Transceiver (10km)
10GBASE-ER, SFP+ Transceiver (40km)
10GBASE-LC, SFP+ Transceiver (80km)
Case Study
More >
  • Sales Enquiry
