Home> Products> Switches > Core Switches>
RG-S8600E Cloud Network Core Switch Series
Ruijie RG-S8600E Switch Series is industry leading in supporting cloud data center with a broad spectrum of specialized campus network features. The RG-S8600E Series achieves cloud network integration, virtualization, and flexible deployment to fulfill the evolving next-gen cloud architecture requirements.
Ruijie brings you an innovative “Network Cloud Mode” featuring a strong core (unified gateway, authentication, multiservice) for easy and simplified access. All service channels including those of the cloud data center and cloud campus network can move to the cloud, building a true channel connecting the services and end users. The feature achieves pooling, demand-based distribution and flexible expansion of all network resources.
The three models RG-S8610E, RG-S8607E and RG-S8605E with various port densities support up to 96 full line-rate interfaces at 40GE or 384 at 10GE. The series is suitable for a wide range of deployment settings such as data center, MAN, campus network and integrated network of data center and campus network.
More+
World’s Leading Performance
Scalable Performance for Future Development
Single slot supports 2Tbps bandwidth (scalable to 8Tbps). The series also supports high-density 40GE and 100GE Ethernet ports to meet the requirements of cloud data center in the coming decade.
The RG-S8600E Series supports up to 170K ARP entries, handling a large amount of online users with ease.
The Series is also market leading in supporting line-rate packet forwarding. The modules including the highest-density all support 64-byte packet forwarding at line rate. The switches thereby guarantee high-speed forwarding with zero packet loss in large-scale data center.
The switches offer ultra-low latency less than 1μs to support high-speed transmission.
Virtualization for Demand-based Allocation
Cloud Data Center Network
Ruijie RG-S8600E Series can also act as the core of the Cloud Data Center Network Solution, and provide a robust and comprehensive set of features that meets the demanding requirements of virtualization and automation in present and future data center environments. A variety of features are embedded in the Ruijie RG-S8600E Series such as Policy Auto-migration, Layer 2 Generic Routing Encapsulation (GRE), Virtual Ethernet Port Aggregator (VEPA).
World’s Leading Cloud Network Core
Ruijie RG-S8600E Series deploys the advanced CLOS multi-plane, multi-stage architecture, which achieves complete separation of the forwarding and control planes. With independent fabric engines and control engines, it ensures all ports are running at full line rate in a non-blocking manner. The solution continues to strengthen bandwidth upgrade and business supporting capacities.
Advanced CLOS Architecture
Using an orthogonal design for service modules and fabric engines, the cross-board traffic is transmitted to the fabric engines through the orthogonal connector. Ruijie RG-S8600E Series achieves zero wiring for backplane with minimized transmission loss and signal degradation. It can also improve internal transmission efficiency of the switch.
Virtual Switch Unit 3.0 (VSU)
The RG-S8600E Series supports the Virtual Switch Unit 3.0 (VSU). The technology can virtualize up to 4 physical devices into one logical unit, which largely minimizes the number of network nodes and reduce maintenance workload. Superior 50~200ms link failover ensures smooth and uninterrupted transmission of key services. The RG-S8600E Series supports cross-device link aggregation for easy double uplink to server/switch, effectively maximizing bandwidth investment return.
Benefits of 4-to-1 Virtualization
Virtual Switch Device (VSD)
The RG-S8600E Series support VSD in which one device can be virtualized into multiple virtual units. Each virtual unit has a unique configuration management interface and independent hardware allocation (e.g. storage, TCAM and hardware forwarding table). All the features support restart with no impact on other virtual machines. Users can realize network resource allocation based on different needs. Resources of the core switch can hence be shared with other domains and users. With the enablement of both VSU3.0 and VSD, the switches satisfactorily deliver complete resource pooling.
Advantages of VSD Technology
With the international L2-GRE standard, the RG-S8600E switches break the geographical boundaries to achieve data center L2 communication. Data center resources at different locations can be centrally managed and allocated.
The Ruijie RG-S8600E Series supports Virtual Ethernet Port Aggregator (VEPA) of the IEEE802.1qbg standard. Data traffic from the server VM can be diverted to the physical network devices for “hard-switching”. This completely eliminates problems such as uncontrollable monitoring of VM traffic, incapability of unified policy deployment and server resources occupation caused by traditional “soft-switching”. All the features together optimize the next-gen data center network solution to fit into the virtual computing environment.
Virtual Machine Perception and Policy Auto-migration
The VM perception and automatic migration of policies features enable centralized deployment of VM traffic security policy in a large-scale server virtualization environment. Teaming up with data center switches and VM management platform via the data center network management platform, it realizes simultaneous policy migration as virtual host can migrate smoothly within the network. It totally gets rid of security loopholes and hence lessens network maintenance workload.
Core Concepts
  • Decoupling of control plane and forwarding plane hardware / network unified abstraction & virtualization, ease of independent development
  • Centralized control & distributed forwarding convert the distributed protocol problem into algorithm problem
  • Open programming interface softwarization of hardware, programmable devices, scalable network features & higher flexibility
Solution Components
  • Hardware Switching Devices:
Ruijie Newton 18000 8600E and S6220 series platform will fully support OpenFlow 1.0/1.3 modular hardware switching
  • SDN Controller RG-IONC
Ruijie Intelligent OpenFlow Network System is an X86 hardware platform, which fully supports OpenFlow 1.0/1.3 and SNMP2.0, providing below SDN control service module:
  • Switch/host/topology management, L2/L3 communication
  • Traffic editing/path calculation/static routing/DHCP
  • MPLS L3 VPN service
  • Virtual tenant network service
Superior Reliability
Redundant design of the RG-S8600E Series key components delivers excellent protection: control engine 1+1 redundancy, fan N+1 redundancy and power module come with N+1 and N+M redundancy for all chassis model S8605E, S8607E and S8610E. All redundant components are hot-swappable to enhance the reliability and availability of the device to the maximum extent. Hot patch and ISSU technologies are also supported to enable online upgrade of devices.
Support GR for OSPF/IS-IS/BGP and BFD for VRRP/OSPF/BGP4/ISIS/ISISv6/MPLS/static routing to enable the fast fault detection mechanism of different protocols. The feature minimizes the fault detection time to less than 50ms.
Since 1998, Ruijie has been investing on the R&D of modular operating system. The RG-S8600E software platform is designed based on the next-generation RGOS 11.X multi-processing modular operating system to integrate the service features such as loosely coupled firewall, wireless, IPFIX and authentication into a unified cloud network operating system. The RG-S8600E software platform also supports full virtualization and offers rich data center and campus network features. The key availability indicators such as multi-processing modules, process backup and hot patch have reached the industry-leading level.
Excellent Energy Efficiency
The RG-S8600E Series adopts 40nm chip technology, which is more energy efficient than the traditional 90nm and 65nm counterparts. Multi-core CPU supports dynamic power management with all fiber ports adopting non-PHY design to reduce power consumption. All Ethernet ports support the Energy-Efficient Ethernet (EEE) standard to save power under light load.
The internal system is designed for low voltage power supply with high-efficiency modular power to form a more efficient power supply system. The smart fan supports 256 speed modulations with precise temperature control, energy saving and noise control. The device can function at high temperature for a long period of time or in harsh environment. The RG-S8600E Series thereby helps clients to maximize savings on air conditioning.
RG-S8605E
RG-S8607E
RG-S8610E
Module Slots
5 (2 for control engines)
7 (2 for control engines)
10 (2 for control engines)
Fabric Engine Slots
NA
NA
16.29Tbps/83.4Tbps
27.15Tbps/139Tbps
43.44Tbps/222.4Tbps
720Mpps
900Mpps
3840Mpps
Number of 10GE
24 (ED module, 10GE ports)
24 (EF module, 10GE ports)
144 (DC module, 10GE ports)
40 (ED module, 10GE ports)
40 (EF module, 10GE ports)
240 (DC module, 10GE ports)
64 (ED module,10GE ports)
64 (EF module,10GE ports)
384 (DC module,10GE ports)
Number of 40GE
ports
36
60
96
8K(EB module)
170K(ED module)
85K(EF module)
75K(DC module)
8K(EB module)
170K(ED module)
85K(EF module)
75K(DC module)
8K(EB module)
170K(ED module)
85K(EF module)
75K(DC module)
32K(EB module)
512K(ED module)
512K(EF module)
288K(DC module)
32K(EB module)
512K(ED module)
512K(EF module)
288K(DC module)
32K(EB module)
512K(ED module)
512K(EF module)
288K(DC module)
Routing Table Size (IPv4/ IPv6)
12K/6K(EB module)
12K/6K(ED module)
384K/128K (EF module)
12K/6K(DC module)
12K/6K(EB module)
12K/6K(ED module)
12K/6K(DC module)
12K/6K(EB module)
12K/6K(ED module)
12K/6K(DC module)
Multicast Entries (IPv4/IPv6)
2K/2K(EB module)
2K/2K(ED module)
2K/2K (EF module)
2K/2K(DC module)
2K/2K(EB module)
2K/2K(ED module)
2K/2K (EF module)
2K/2K(DC module)
2K/2K(EB module)
2K/2K(ED module)
2K/2K (EF module)
2K/2K(DC module)
2.5K(EB module)
7K(ED module)
7K(EF module)
8K(DC module)
2.5K(EB module)
7K(ED module)
7K(EF module)
8K(DC module)
2.5K(EB module)
7K(ED module)
7K(EF module)
8K(DC module)
4K
4K
4K
MST
256
256
256
60(EB module)
2K(ED module)
1K (EF module)
2000(DC module)
60(EB module)
2K(ED module)
1K (EF module)
2000(DC module)
60(EB module)
2K(ED module)
1K (EF module)
2000(DC module)
VSU3.0 (Virtual Switch Unit)
Virtualized Bandwidth≥2.56Tbps
VSD (Virtual Switch Device)
Network Virtualization
L2GRE(ED/EF/DB/DC module support)
Edge Virtual Switching
VEPA (Virtual Ethernet Port Aggregator) (ED/EF/DB/DC module support)
Automatic Virtual Machine Migration(ED\EF\DB module support)
OpenFlow 1.0
Jumbo Frame
802.1Q
STP, RSTP, MSTP
QinQ, flexible QinQ
Up to 4K 802.1q VLANs
Super VLAN
Protocol VLAN
Static routing, RIP, OSPF, IS-IS, BGP4
Equal-cost routing
Policy-based routing
GRE Tunnel
Static routing OSPFv3, BGP4+, IS-ISv6, MLDv1/v2
VRRPv3
Equal-cost routing
Manual tunnel, Auto tunnel, ISATAP tunnel, GRE tunnel
IGMP v1, v2, v3
IGMP Snooping
IGMP Proxy
Multicast routing protocols (PIM-DM, PIM-SM, PIM-SSM)
MLD
MPLS forwarding
MPLS VPN/VPLS
VPWS
Standard, Extended, Expert ACL
802.1p
Queue scheduling mechanisms (SP, WRR, DRR, SP+WRR, SP+DRR)
RED/WRED
Input/output port-based speed limit
Independent fabric engine and control engine design which allows separation of forwarding and control planes
Control engine supports 1+1 redundancy
Fabric engine supports N+1 redundancy
Power supply and fan support N+M redundancy
Passive backplane design to avoid single point of failure
Hot-swappable components
Support hot patch and online patch upgrade
ISSU
NFPP (Network Foundation Protection Policy)
CPP (CPU Protection)
DAI, Port Security, IP Source Guard
802.1x
Portal authentication, RADIUS and TACACS+ user login authentication
Account privileges and password security policy
Unknown multicasts are not delivered to CPU and support unknown unicasts suppression
Support SSHv2 to provide a secure and encrypted channel for user login
Console/AUX Modem/Telnet/SSH2.0 command line configuration
FTP, TFTP, Xmodem, SFTP file upload/download management
SNMP V1/V2c/V3
RMON
NTP clock
Fault alarm and self-recovery
System log
IPFIX flow analysis
(W x D x H) (mm)
442 x 595 x 219.5 (5U)
442 x 595 x 352.8 (8U)
442 x 821 x 797.3 (18U)
RG-PA1600I: 90-180V~1200W; 180-264V~ 1600W
RG-PA1600I-P: 90-180V~1200W; 180-264V~ 1600W
>200K hours
Operating temperature: 0℃ to 50℃
Storage temperature: -40℃ to 70℃
-500 to 5000M
IEC 60950-1, EN 60950-1
Emissions
Weight and Typical Power
Below table lists maximum power consumption of the RG-S8600E switch platform.
Component
Maximum Power
Main Chassis
Ruijie RG-S8605E chassis with fan
20.2 kg
288W
Ruijie RG-S8607E chassis with fan
30.2 kg
432W
Ruijie RG-S8610E chassis with fan
78.66 kg
730W
Control Engine
M8600E-CM
1.68 kg
40W
RG-PA600I – 600W
1.64 kg
RG-PD600I – 600W
1.3 kg
RG-PA1600I – 1600W
2.04 kg
RG-PD1600I – 1400W
1.6 kg
RG-PA1600I-P – 1600W
1.6 kg
Line Card & Service Module
M8600E-44SFP4XS-ED
3.76 kg
135W
M8600E-48GT-ED
3.7 kg
95W
M8600E-24GT20SFP4XS-ED
3.76 kg
100W
M8600E-08XS-ED
3.42 kg
85W
M8600E-48GT-P-ED
4.04 kg
815W
M8600E-48XS-DC
4.25 kg
212W
M8600E-12QXS-DC
3.92 kg
200W
M8600E-24XS4QXS-DC
4.0 kg
188W
M8600E-44SFP4XS-EF
3.86 kg
175W
M8600E-48GT-EF
3.8 kg
125W
M8600E-08XS-EF
3.52 kg
120W
M8600E-24SFP/8GT-EB
3.2 kg
72W
M8600E-24GT/8SFP-EB
3.25 kg
58W
RG-WALL 1600-B-ED
4.58 kg
190W
RG-S8600E-WS-ED
4.58 kg
190W
Large Campus Network Core/Aggregation
Medium/Small-Scaled Network Core
Data Center Network Core
Campus Network & Data Center Network Core
Main Chassis & Engine Management
RG-S8600E Series Main Chassis & Control Engine
S8610E-I Series
S8607E-I Series
S8605E-I Series
5-slot Chassis with fan (without power supply)
M8600E-CM
S8600E Control Engine
Select at least 1 power module according to the power supply requirement of the device.
RG-PA600I
S8600E Power Module (support redundancy, AC, 600W)
RG-PD600I
S8600E Power Module (support redundancy, DC, 600W)
RG-PA1600I
S8600E Power Module (support redundancy, AC, 1600W)
RG-PD1600I
S8600E Power Module (support redundancy, DC, 1400W)
RG-PA1600I-PL
S8600E PoE power module (support redundancy, AC, 1600W)
RG-PA3000I-PL
S8600E PoE power module (support redundancy, AC, 3000W)
Select the host line cards according to your real application.
Commercial Line Card
M8600E-44SFP4XS-ED
44 Gigabit Ethernet fiber ports (SFP, LC), 4-port 10GE Ethernet optical line card (SFP+, LC)
M8600E-44SFP4XS-EF
M8600E-48GT-ED
48-port Gigabit Ethernet electrical line card (RJ45)
M8600E-48GT-EF
24-port Gigabit Ethernet electrical line card (RJ45), 20 Gigabit Ethernet fiber ports (SFP, LC), 4 10GE Ethernet fiber ports (SFP+, LC)
M8600E-08XS-ED
8 10GE fiber ports (SFP+, LC)
M8600E-48GT-P-ED
48-port Gigabit Ethernet line card (RJ45), support PoE and PoE+
M8600E-08XS-EF
M8600E-24SFP/8GT-EB
24 Gigabit Ethernet fiber ports (SFP, LC), 8-port Gigabit Ethernet line card (RJ45) combo
M8600E-24GT/8SFP-EB
24-port Gigabit Ethernet line card (RJ45), 8 Gigabit Ethernet fiber ports (SFP, LC) combo
Data Center Line Card
M8600E-48XS-DB
M8600E-12QXS-DB
M8600E-24XS4QXS-DB
24 10GE fiber ports (SFP+, LC) + 4-port 40GE Ethernet optical line card (QSFP+, MPO)
Transceiver and Cable
10GBASE-SR, SFP+ Transceiver (300m)
10GBASE-LR, SFP+ Transceiver (10km)
10GBASE-ER, SFP+ Transceiver (40km)
10GBASE-LC, SFP+ Transceiver (80km)
40G-QSFP-STACK3M
40G Copper Cable for QSFP+, 3m
40G LR Single-mode Fiber Module, QSFP+ Transceiver, LC (1310nm)
  • Sales Enquiry
