Home> Products> Switches > Data Center Switches>
RG-S6220-H Switch Series
Ruijie's industry-leading RG-S6220H Switch Series, designed to power next-generation data centers and cloud computing services, delivers non-blocking, unified and virtualized switching performance with high transparency and sustainability. The high-performance and cost-efficient RG-S6220H Switch Series solves the problems such as traffic surge and high deployment cost, serving as the solid foundation for cloud computing network solutions.
The RG-S6220H Switch Series pushes the frontier with its 10G cloud-computing data center switches for the IP network. To comply with the trend of data center and cloud computing virtulization, the RG-S6220H Switch Series adopts the industry-leading VSU 2.0 technology, which enables virtualization of multiple physical equipments into one, significantly simplifying the network structure and increasing the equipment reliability. The RG-S6220H Switch Series also supports virtual machine discovery, automated migration of security policies and other next-gen data center virtualization features. Gearing up with the IPv4/IPv6 dual-stack multi-layer switching features, the RG-S6220H Switch Series offers abundant Tunnel technologies which can be applied to IPv4, IPv6 or IPv4/IPv6 hybrid network.
Featuring a smart traffic classification from Layer 2 to Layer 7 as well as a refined Quality of Service strategy, the RG-S6220H Switch Series can scale the service flow classification according to different applications to ensure the low-latency data transmission.
The feature-rich switches provide end-to-end QoS, and excellent virtualization performance for next-generation data centers. The series is ideal for the access layer of large data center networks, the convergence or core layer of medium and small data center networks, the convergence layer of large campus networks, as well as the core layer of medium and small networks.
Feature highlights of RG-S6220H Switch Series:
●Data Centre Virtualization (EVPN VXVLAN, VSU 2.0, OpenFlow) Support
●Non-Blocking Performance with Powerful Caching Capacity
●Up to 48 x 10G BASE-X/BASE-T Ports and 32 x 40G BASE-X Ports
●Advanced Layer 3 Routing Support
●Power and Fan Redundancy Support
More+
RG-S6220 Series Data Center Switch
Data Center and Cloud Computing 10G Switch
Both data center features and campus network features are supported
Rich data center features are supported to ensure network integration and virtual switching
The RG-S6220 series is applicable to scenarios such as data centers, campus networks, and MANs based on service requirements
  • RG-S6220-48XS6QXS-H
  • RG-S6220-48XT6QXS-H
  • RG-S6220-32QXS-H
High Performance, Meeting Service Requirements
A single switch provides a maximum of 48 fixed 10GE ports and 6 fixed 40GE ports, and all of the ports can support the line rate.
10GBase-T electrical ports are supported to connect to 10G electrical servers, ensuring cost-effective networking.
The RG-S6220-32QXS-H supports 32 fixed 40GE ports ensuring high-speed data center networking.
Virtual Switching
The VSU2.0 technology can be used to virtualize multiple core switches into one logical device, ensuring network resource pooling.
A maximum of nine devices can be virtualized into one logical device, to improve network reliability, ensure load balancing between data links,
and implement unified management across the whole logical unit.
The VEPA technology is supported, which diverts traffic of virtual servers to physical switches, improving the security and
traffic controllability of the virtual servers.
Security policies can be migrated with VMs, ensuring automatic following of security policies during VM migration.
Layer-2 networking, meeting VM migration service requirements
EVPN VXLAN, ensuring multi-tenant isolation
Anycast gateway, ensuring optimal forwarding path
Tolly Group, International Authority for Testing and Certification
Tolly Group, an international third-party authority for testing and certification,
proves the superb performance of RG-S6220 series data center 10G TOR switches.
Only 1 RU, 48 Fixed 10GE Ports, and Six Fixed 40GE Ports
A single switch provides a maximum of 48 fixed 10GE ports and 6 fixed 40GE ports, supporting the full line rate.
RG-S6220-48XS6QXS-H provides 48 fixed 10GE SFP ports and six fixed 40GE ports.
RG-S6220-48XT6QXS-H provides 48 fixed 10GBase-T electrical ports ports and six fixed 40GE ports.
10GBase-T Electrical Ports, Ensuring Cost-Effective Networking
10GE networks can be built with only RJ-45 network cables. The cost is low, and the power consumption over ports is lower than that of conventional
Virtual Switching
Nine Devices Virtualized into One Device, Ensuring Network Resource Pooling
A maximum of nine devices can be virtualized into one logical device to improve network reliability, ensure load-balancing between data links,
and meanwhile implement unified management of the entire logical unit.
VM Traffic Diversion, Improving VM Security and Traffic Controllability
improving the security and traffic controllability of the virtual servers.
Automatic Migration and Following of Security Policies
Layer-2 Networking, Meeting VM Migration Service Requirements
VXLAN ensures layer-2 networking across IP networks through UDP tunnels, ensuring VM migration between two TOR switches
The control plane protocol MP-BGP EVPN can automatically synchronize host information among TOR switches. It provides transmission
support for large-scale VXLAN deployment and meets VM migration service requirements
EVPN VXLAN, Ensuring Multi-tenant Isolation
Tenant data can be transmitted through different TOR switches, and different tenants or services can be logically isolated using EVPN VXLAN.
Anycast Gateway, Ensuring Optimal Forwarding Path
The Anycast gateway is supported. The server directly connects to the TOR switch, and each TOR switch can serve as a gateway,
so that the service flow forwarding path provided by the server to external devices is optimal.
RG-S6220 Series Superb Performance Proved by Tolly Group
The TRILL technology of the N18000 and S6220 series switches are used to build two layer-2 networks,
so that the N18000 L2GRE technology is used to build a layer-2 network between two data centers.
RG-S6220-48XS6QXS-H
RG-S6220-48XT6QXS-H
RG-S6220-32QXS-H
RG-S6220-48XS4QXS-L
48 fixed 10G SFP+ ports
6 40G QSFP+ ports
48 fixed 10GBASE-T ports (RJ 45)
6 40G QSFP+ ports
32 fixed 40G QSFP+ ports
48 10G SFP+ ports, 4 40G QSFP+ ports
Modular Power Slots
Fan Slots
Management Ports
1 MGMT port
1 USB 2.0 port
1 mini USB console port
1 MGMT port
1 USB 2.0 port
1 MGMT port
1 USB 2.0 port
1 MGMT port
1 USB 2.0 port
2.56Tbps
2.56Tbps
2.56Tbps
1.28T
1,080Mpps
1,080Mpps
1,440Mpps
960Mpps
16MB
16MB
16MB
9MB
Up to 40K
Up to 40K
Up to 40K
Up to 750
Up to 96K
Up to 96K
Up to 96K
Up to 128K
Up to 2K
Up to 2K
Up to 2K
Up to 750
Multicast Entries (IPv4/IPv6)
Up to 16K
Up to 16K
Up to 16K
Up to 8K
Up to 8K
Up to 8K
Up to 1,200
4K VLANs, Port-based VLAN, MAC-based VLAN, Super VLAN, Protocol-based VLAN, Private VLAN, IP subnet-based VLAN, GVRP
Basic QinQ, Flexible QinQ
Support LACP
IEEE802.1d STP, IEEE802.1w RSTP, Standard 802.1s MSTP, Port fast, BPDU filter, BPDU guard, TC guard, TC protection, Loop guard, Root guard
DHCP server, DHCP client, DHCP snooping, DHCP relay, IPv6 DHCP relay
DHCP server, DHCP client, DHCP relay, DHCP snooping
64 (not include default 0)
Up to 256
Up to 48
Up to 2K
Up to 2K
Up to 2K
Virtualization:
Virtual Switch Unit (VSU), EVPN VXLAN, OpenFlow
Virtualization:
Virtualization:
Support (up to 4 stack members)
MAC, ARP, VLAN, Basic QinQ, Felix QinQ, Link aggregation, Mirroring, STP, RSTP, MSTP, Broadcast storm control, IGMP v1/v2/v3 snooping, IGMP filter, IGMP fast leave, MLD snooping, DHCP, Jumbo frame, RLDP, LLDP
AP, Ethernet, MSTP, STP, Storm suppression, Mirroring, VLAN, Basic QinQ, Flexible QinQ, MAC, RLDP, LLDP, REUP, G.8032, BPDU Tunnel
IEEE802.3 (10BASE-T), IEEE802.3u (100BASE-T), IEEE802.3z (1000BASE-X), IEEE802.3ab (1000BASE-T), IEEE802.3ae (10GBASE-T), IEEE802.3an (10GBASE-T), IEEE802.3ak, IEEE802.3an, IEEE802.3x, IEEE802.3ad (link aggregation), IEEE802.1p, IEEE802.1x, IEEE802.1Q, IEEE802.1D (STP), IEEE802.1w (RSTP), IEEE802.1s (MSTP), IGMP snooping, Jumbo Frame (9Kbytes), IEEE802.1ad (QinQ and flexible QinQ), GVRP
Layer 3 Features
ARP, IPv4/v6, PBRv4/v6
ARP, IPv4
Layer 3 Protocols (IPv4)
BGP4, OSPFv2, RIPv1, RIPv2, MBGP, LPM routing, Policy-based routing, Route-policy, ECMP, WCMP, VRRP, IGMP v1/v2/v3, DVMRP, PIM-SSM/SM/DM, MSDP, Any-RP, ISIS
Ping, Traceroute, Equal-cost routing, URPF, IPIP, GRE tunnel, VRF
Static routing Equal-cost routing, Policy-based routing, OSPFv3, RIPng, BGP4+, MLDv1/v2, PIM-SMv6, Manual tunnel, Auto tunnel, IPv4 over IPv6 tunnel, ISATAP tunnel
ND, ICMPv6, Path MTU Discovery, DNSv6, DHCPv6, ICMPv6, ICMPv6 redirection, ACLv6, TCP/UDP for IPv6, SNMP v6, Ping /Traceroute v6, IPv6 RADIUS, Telnet/SSH v6, FTP/TFTP v6, NTP v6, IPv6 MIB support for SNMP, VRRP for IPv6, IPv6 QoS, ISISv6
Static routing, Equal-cost routing, Policy routing, RIP, RIPng, OSPFv2/v3, BGP4, BGP4+, IS-IS
IPv6 Tunnel Features
Manual tunnel, Auto tunnel, 6over4 manual tunnel, 6to4 auto tunnel, ISATAP, IPv4 over IPv6 tunnel, IPv6 over IPv6 tunnel, GRE tunnel
IGMP v1/v2/v3, IGMP proxy, MSDP, PIM-DMv4 (PIM-DM), PIM-SMv4 (PIM-SM, PIM-SSM), PIM-SM v6, MLD, MLD Proxy
Standard/Extended/Expert ACL, Extended MAC ACL, ACL 80, IPv6 ACL
Standard IP ACL, Extended MAC ACL, Extended IP ACL, Expert ACL, ACL 80, Layer 2-based association ingress ACL, Layer 3-based association ingress ACL, physical interface-based/AP association egress ACL, ACL logging, ACL counter, ACL remark, Global ACL, ACL redirection
EXP priority mapping based on 802.1p, DSCP, TOS and IP Precedence; ACL traffic classification; Priority marking/remarking; Multiple queue scheduling mechanisms, such as SP, WRR, DRR, SP+WRR, and SP+DRR
802.1p, DSCP remarking; IP precedence remarking;
EXP priority mapping based on 802.1p DSCP and IP precedence; Congestion avoidance (tail drop); RED/WRED; Egress flow-based rate limiting; Ingress flow-based rate limiting; Voice VLAN; Multiple queue scheduling mechanisms, such as SP, WRR, DRR, SP+WRR and SP+DRR
VSU (virtualization technology for virtualizing multiple devices into 1); GR for OSPF/IS-IS/BGP; BFD detection; ERPS (G.8032); REUP dual-link fast switching technology; RLDP (Rapid Link Detection Protocol); 1+1 power redundancy; 2+1 fan redundancy; Hot-swappable line cards and power modules
VSU (hot standby between chassis, VSL link interface, IP-BFD-based dual chassis detection, MADP-based dual chassis detection, MADP-based dual chassis detection) RNS, Track, BFP correlation with static routing, Hot standby, Oscillation suppression
Network Foundation Protection Policy (NFPP); CPU Protection (CPP); DoS protection; Detection of unauthorized data packets; Data encryption; IP source guard; RADIUS / TACACS+; IPv4 / IPv6 ACL packet filtering based on standard or extended VLANs; Plaintext authentication and MD5 cipher-text authentication of OSPF, RIPv2, and BGPv4 packets; Telnet login through limited IP addresses and the password mechanism; uRPF; Broadcast packet suppression; DHCP snooping; Anti-gateway ARP spoofing; ARP check
Network Foundation Protection Policy (NFPP); CPP; RADIUS/TACACS+; IP source guard; Authentication server redundancy; SSHv1.5; SCP file transmission; MAC-based 802.1X; SU auto dispatching; MAB supporting multi-tenant mode; Port security (IPv4+MAC binding); Anti-gateway ARP spoofing; DAI; CPP; DOS Protection; Trustable ARP; ARP check; Security portal
SNMP v1/v2c/v3; Telnet; Console; Hardware support RCMI (combo interface for DCMI and MGMT); Web; RMON; SSHv1/v2; FTP/TFTP for file upload and download management; NTP clock; Syslog; SPAN/RSPAN
SNMP v1/v2/v3; RMON; SFLOW, Syslog/Debug, USB logging storage, limit the interfaces of network management (only specific interfaces will be allowed with network management while the rest are not allowed)
Hot Patch
Smart Power Supply
Support power management
DHCP client, DHCP relay, DHCP server, DNS client, UDP relay, ARP proxy, Syslog
DNS client, DHCP relay, DHCP snooping, DHCP Server, DHCP Client, Telnet, TFTP, FTP, NTP, OpenFlow, UDP Helper
(W x D x H) (mm)
420 × 420 × 44
442 × 500 × 44
442 × 420 × 44
440 × 420 × 44
9kg
(incl. fan modules and power modules)
11kg
9kg
9kg
 (incl. power modules and fan modules)
>200K hours
Frequency: 50/60Hz
Rated current: 5.29A to 2.2A
Input current range: 2.66A to 2.03A
<200W
<250W
<200W
<180W
The topology diagram of the government and enterprise Active/Active data center and the large-scale Internet data center is shown in figure below:
Typical Application of the RG-S6220H Switch Series
1. Chassis, expansion modules, fans, and power modules
RG-S6220-48XS6QXS-H
48 fixed 10G SFP+ Ports, 6 40G QSFP+ Ports
RG-S6220-48XT6QXS-H
48 fixed 10GBASE-T Ports, 6 40G QSFP+ Ports
RG-S6220-32QXS-H
32 fixed 40G QSFP+ Ports
RG-S6220-48XS4QXS-L
48 fixed 10G SFP+ Ports, 4 40G QSFP+ Ports
M6220-12XS
Expansion module, 12 SFP+ ports
M6220-08XT
Expansion module, 8 10G BASE-T ports
M6220-02QXS
Expansion module, 2 40G QSFP+ ports
M6220-FAN-F
Fan Module, front-to-rear airflow
M6220-FAN II-F
RG-M6220-AC460E-F
AC power supply module (front-to-rear airflow) with up to 2 power modules, support 1+1 redundancy,
RG-M6220-DC460E-F
DC power supply module (front-to-rear airflow) with up to 2 power modules, support 1+1 redundancy
2. Optional 40G and 10G fiber modules
40G SR Fiber Module for QSFP+ ports, 100m (OM3) / 150m (OM4)
(8 cores, 850nm)
40G SR Fiber Module for QSFP+ ports, 300m (OM3) / 400m (OM4)
(8 or 12 cores, 850nm)
40G-QSFP-LR4-PSM-SM1310
40G LR Single-mode 1-to-4 Fiber Module for QSFP+ ports, 10km (LC)
(1310nm)
40G LR Single-mode Fiber Module for QSFP+ ports, 10km (LC)
(2 cores, 1310nm)
10G SR Fiber Module for SFP+ ports, 300m
10G LR Fiber Module for SFP+ ports, 10km
10G ER Fiber Module for SFP+ ports, 40km
10G ZR Fiber Module for SFP+ ports, 80km
3. Optional 40G and 10G copper cables
40G-QSFP-STACK3M
40G Copper Cable for QSFP+ interface, 3m, including 1 cable and 2 modules
XG-SFP-CU1M
1m SFP+ Cable, including 1 cable and 2 modules
XG-SFP-CU3M
3m SFP+ Cable, including 1 cable and 2 modules
XG-SFP-CU5M
5m SFP+ Cable, including 1 cable and 2 modules
4. Optical Gigabit modules
Case Study
More >
  • Sales Enquiry
