Home> Products> Switches > Small Business Switches>
RG-S1800 Series
Ruijie RG-S1800 Series Unmanaged Switches deliver basic network connectivity and reliability for small businesses which are easy on the budget and without all the complexity. These switches provide all of the features, expandability, and investment protection you expect from Ruijie, with no installation software and zero configuration required. Just plug it in, connect your computers and other business equipment, and the device will be ready to use.
Ruijie RG-S1800 Series Unmanaged Switches are a line of unmanaged switches that provide wire-speed Gigabit Ethernet connectivity to connect your small business office. Available in desktop and rack-mount models, these switches are designed to suit any office space with basic network needs and to optimize power efficiency.
The Ruijie RG-S1800 Series Unmanaged Switches are suitable for video surveillance networks and support PoE+. They can be used for parks, office buildings, residential, parking and other video surveillance environments for camera access. The switches have larger port buffer to ensure a smooth video transmission.
Feature Highlights of RG-S1800 Series Unmanaged Switches:
●Affordable 10/100/1000Mbps speeds for even the most bandwidth-hungry applications
●Desktop or rack mountable models with 8 to 26 ports
●Power over Ethernet Plus models to provide power to IP phones, access points, cameras and other devices
●Work right out of the box: plug and play with no setup
More+
Ease of Use
Ruijie RG-S1800 Unmanaged Series switches work right out of the box, with no software to install and zero configuration required. Each switch port independently sets itself for the optimal speed and determines whether to run in half- or full-duplex mode automatically.
Ruijie RG-S1800 Unmanaged Series switches are also designed to immediately accommodate all of the devices in your network, including:
○Support for 10 Mbps, 100 Mbps, and up to 1 Gbps (1000 Mbps) devices in the same network
○Automatic cable detection, so users do not have to concern about using the wrong cable type
○Compatibility with network devices from other vendors
High Performance in Bandwidth-intensive Video Services
●Gigabit Ports and Larger Port Buffer
In the video surveillance environment, each video traffic averages 4-8Mbps, and from the actual traffic analysis with analysis duration of 10ms, the burst traffic of video surveillance can even reach 50Mbps. The traditional switches cannot meet the video surveillance requirement of the large uplink bandwidth. Ordinary unmanaged switches are designed for PC networks, and the cache is typically designed at 128K-512K.
In response to this feature, all of the uplink ports of the RG-S1800 are designed for Gigabit ports and with large port buffer to meet the characteristics of video surveillance burst traffic, thereby preventing the phase lag of the videos.
●SFP Support
For video surveillance coverage, the cameras are usually far away from the central telecom room. Due to the costs of the traditional switches, especially the low-end unmanaged switches, they generally do not provide SFP port. Therefore, in the field of surveillance, in order to solve the challenges of long-distance transmission, engineers have to use a large number of photoelectric conversion modules.
On the one hand, the photoelectric conversion modules are active devices. They must be used in pairs, and they require independent power supplies, which result in a large number of receiving end of the photoelectric conversion modules in the central telecom room and cause difficulty for wiring. On the other hand, the large amount of low-cost photoelectric conversion modules flooding the market may cause a high incidence of failure.
Ruijie RG-S1800 Series supports SFP ports. According to the deployment distance, you can use optical fiber module for fiber optic transmission. It does not only eliminate the cost of purchasing photoelectric converters, but also reduces the failure of the entire solution.
RG-S1826G-P
Safety and Savings from PoE+
RG-S1809-P\RG-S1826G-P switches are available with PoE+ ports. This capability simplifies the deployment of IP telephony, wireless, video surveillance, and other solutions by allowing you to connect and power network endpoints over a single Ethernet cable. With no need to install separate power supplies for IP phones, wireless access points and cameras, you can take advantage of the advanced communications technologies more quickly and at a lower cost.
●Time and Cost Savings
Electrical wiring involves a series of construction work and tests, which means requiring more human resources, longer implementation period and higher deployment costs. The wiring work sometimes costs even more than that of device purchase. The PoE+ deployment does not only help users to save costs on wiring and labor, but the service also turns up faster than any traditional solutions.
●Power Supply Safety
Getting power over electrical wiring features low loss and high efficiency. However, the high power, voltage and current are potential hazards to technicians during installation or maintenance stages. The PoE+ technology carries power on cables (twisted pair) with low voltage, which offers improved safety.
●Device Safety
High power is also a threat to devices. With thunderstorm or electromagnetic interference, devices are vulnerable under high current. The PoE device, on the other hand, implements various protection mechanisms. When an IP camera breaks down or short circuit is detected, the device will remain intact under the overcurrent protection.
The device also supports lightning protection up to 6KV, ensuring stable operation under severe weather conditions.
Ruijie S1800 Series Unmanaged Switches
RG-S1808
RG-S1826
RG-S1808G
RG-S1818G
RG-S1826G
RG-S1809-P
RG-S1826G-P
8 10/100BASE-T
24 10/100BASE-T, 2 10/100/1000BASE-T and 2 GE SFP (combo)
8 10/100/1000BASE-T
16 10/100/1000BASE-T, 2 GE SFP (Non-combo)
24 10/100/1000BASE-T, 2 GE SFP (Non-combo)
8 10/100BASE-T, 1 10/100/1000BASE-T
All models support half-duplex, full-duplex, auto-negotiation mode, automatic medium dependent interface (MDI) and MDI crossover (MDI-X)
Power over Ethernet Plus (PoE+)
PoE Power Budget:118W
PoE Power Budget:370W
768Kbits
4Mbits
1.5Mbits
4Mbits
4Mbits
1.5Mbits
4Mbits
1.6Gbps
48Gbps
16Gbps
48Gbps
48Gbps
3.6Gbps
48Gbps
Forwarding Capacity
1.19Mpps
6.60Mpps
11.90Mpps
26.80Mpps
38.70Mpps
2.68Mpps
38.70Mpps
4K
8K
4K
8K
8K
4K
8K
DC 5V/550mA
AC 100~240V  50Hz~60Hz
3W
5.5W
5.3W
8.6W
22.8W
3.5W (w/o PoE)
22.8W (w/o PoE)
Surge Protection
4KV
4KV
4KV
4KV
4KV
6KV
6KV
Fan/Fanless Models
Support fan module
Physical Dimensions (W x D x H)
140*76*27mm
440*205*44mm
220*160*44mm
440*205*44mm
440*205*44mm
190*100*28mm
440*205*44mm
0℃~50℃
-40℃~70℃
10%~90% RH
5%~95% RH
-500m to 2,000m
EN60950-1
Emission Standards
EN 55032, EN 61000-3-2, EN 61000-3-3, EN 55024, EN 61000-4-2, EN 61000-4-3, EN 61000-4-4, EN 61000-4-5, EN 61000-4-6, EN 61000-4-8, EN 61000-4-11,EN300 386
The RG-S1800 Series Unmanaged Switches includes 8 models and offers a broad range of port types, including 8/16/24 1000M/100M copper/SFP ports, which can be used in various security protection and access surveillance scenarios.
download book
download book
The RG-S1800 Series Unmanaged Switches include 8 models and offer a broad range of port types, including 8/16/24 100M/1000M copper/SFP ports, which can be used in various security protection and access surveillance scenarios.
Cameras
Security Protection and Video Surveillance Scenario
RG-S1808
Unmanaged Switch, 8 10/100BASE-T
RG-S1826
Unmanaged Switch, 24 10/100BASE-T, 2 10/100/1000BASE-T and 2 GE SFP (combo)
RG-S1808G
Unmanaged Switch, 8 10/100/1000BASE-T
RG-S1818G
Unmanaged Switch, 16 10/100/1000BASE-T, 2 GE SFP (Non-combo)
RG-S1826G
Unmanaged Switch, 24 10/100/1000BASE-T, 2 GE SFP (Non-combo)
RG-S1809-P
Unmanaged Switch, 8 10/100BASE-T, 1 10/100/1000BASE-T, Number of PoE+ Ports: 1-8, PoE Power Budget:118 watts
RG-S1826G-P
Unmanaged Switch, 24 10/100/1000BASE-T, 2 GE SFP (Non-combo), Number of PoE+ Ports: 1-24, PoE Power Budget:370 watts
1000BASE-SX, SFP Transceiver, MM (850nm, 550m, LC)
1000BASE-LX, SFP Transceiver, SM (1310nm, 10km, LC)
1000BASE-LH, SFP Transceiver, SM (1310nm, 40km, LC)
1000BASE-ZX, SFP Transceiver, SM (1550nm, 50km, LC)
1000BASE-ZX, SFP Transceiver, SM (1550nm, 80km, LC)
1000BASE-ZX, SFP Transceiver, SM (1550nm, 100km, LC)
  • Sales Enquiry
