Home> Products> Switches > Access Switches>
XS-S1920 Series Switches
Ruijie XS-S1920-E/RG-S1920 Series Switches are the next-generation cost-effective smart managed Layer 2 switches for commercial real estate, hotels and CCTV. The series is designed for small and medium-sized businesses looking for easy-to-deploy solution.
Ruijie S1920 Series is part of the Ruijie SME networking products. The series consists of 7 switches including one 8-port Gigabit PoE+ models, one 16-port Gigabit model, one 24-port Gigabit model, two 24-port Fast Ethernet PoE+ models, and two 24-port Gigabit PoE+ switch models.
These switches can be deployed with plug-and-play out the box. Also they can be fine-tuned with features available from built-in Web-UI as well as command lines(CLI). Features including VLAN, Spanning Tree, IGMP Snooping can be configured.
With Ruijie Cloud, fast deployment, centralized monitoring and remote maintenance can be done in more efficient ways. Using Smart+ features for CCTV, configurations for IP cameras can be done automatically on PoE models, lots of man power and time saved on site.
Key Features
Efficient management using Ruijie Cloud, Web-UI and command lines
24-port 10/100, 8-, 16- and 24-port Gigabit models with GT and SFP ports for uplink
All 8/24 ports are PoE/PoE+ capable on PoE models
Extra surge protection of 8KV on PoE models and 10KV on non-PoE models
Wide operating temperature from -5℃ to 55℃
Unique Smart+ features including Auto Smart Deployment and Remote Reboot Helper guarantee the experience on CCTV networks
More+
Easy Management
Ruijie Cloud Web and App
The S1920 Series fully supports Ruijie Cloud, which is a cloud-based service that helps user deploy and manage devices and networks. Now using Ruijie Cloud mobile app, monitoring and simple maintenance job for switch can be done remotely on a cellphone. More professional operations can be done on Ruijie Cloud Website.
Built-in Web management
Even non-technical users can do easy management for the network through a Web browser and S1920’s Web-UI.
Command Line Interface
With RGOS’s full command line support, complex configuration and troubleshooting can be done as well.
Switches can be discovered and monitored from NMS system or other SNMP-based network tools.
Network Time Protocol
Enables synchronization of time among time servers and clients, fulfill the need for clock-dependent devices in the network.
Unique Smart+ Features for CCTV
IP cameras and NVRs will be identified by switch, and configurations like MTU, flow-control and port isolations will be deployed automatically.
With the help of Ruijie Cloud or switch’s Web-UI, PoE IP cameras can be reboot without unplugging the wire on site.
High Performance
IGMP Snooping v1/v2/v3
Instead of flooding traffic to all ports, the switch filters multicast traffic to improve network performance, especially useful for IPTV and CCTV deployment.
VLAN support and tagging
Supports IEEE802.1Q VLAN, providing security between device groups.
Jumbo Frame support
Improves the performance of large data packet transfers, supports frame size up to 9216 Bytes.
Connectivity and Resiliency
SFP ports for fiber connectivity
Provides fiber uplinks on all models. SFP ports are in addition to RJ45 Ethernet ports, providing higher total number of available ports.
Power over Ethernet(PoE/PoE+)
5 PoE models provide up to 30Watt per port, which allows support of latest PoE+ capable devices such like high-performance access points and IP cameras, as well as any IEEE802.3af(PoE)-compliant powered devices.
For XS-S1920-9GT1SFP-P-E, Ports 1-8 provide PoE/PoE+. For other four 24-port PoE models, Ports 1-24 provide PoE/PoE+.
STP, RSTP and MSTP
Supports IEEE802.1D(STP), IEEE802.1w(RSTP) and IEEE802.1s(MSTP) standards, provides redundant links while preventing network loops.
Rapid Link Detection Protocol(RLDP)
RLDP detects the connectivity of links, and supports the enhanced loop detection function to prevent network faults caused by devices such as Hubs.
Energy Efficient Ethernet(EEE)
Compliant with IEEE802.3az standard requirements in order to save energy.
Warranty and support
3-Year Warranty Free of Charge
Go to https://www.ruijienetworks.com/support/servicepolicy to see details on warranty and support policies.
XS-S1920-26GT2SFP-P-E
XS-S1920-26GT2SFP-LP-E
XS-S1920-24T2GT2SFP-P-E
XS-S1920-24T2GT2SFP-LP-E
RG-S1920-18GT2SFP
RG-S1920-24GT4SFP/2GT
10/100BASE-T
n/a
n/a
n/a
24
24
n/a
n/a
10/100/1000BASE-T
26
26
1000M SFP
4 (with 2 combo)
Power over Ethernet
n/a
n/a
PoE/PoE+
Enabled Ports
24
24
24
n/a
n/a
IEEE802.3af
(PoE)
n/a
n/a
IEEE802.3at
(PoE+)
n/a
n/a
PoE Power Budget
125W
370W
185W
370W
185W
n/a
n/a
Physical
Packet Buffer
4.1Mbit
4.1Mbit
4.1Mbit
4.1Mbit
4.1Mbit
4.1Mbit
4.1Mbit
CPU Memory
256MB
256MB
256MB
256MB
256MB
256MB
256MB
Flash
32MB
32MB
32MB
32MB
32MB
32MB
32MB
Dimensions(WxDxH)
300x220x43.6mm
440x292x43.6mm
440x292x43.6mm
440x292x43.6mm
440x292x43.6mm
440x189x43.6mm
440x189x43.6mm
Surge Protection
8KV
8KV
8KV
8KV
8KV
10KV
10KV
Unit Weight
2kg
4.2kg
4.2kg
4.2kg
4.2kg
2.4kg
2.4kg
Type
Internal
Internal
Internal
Internal
Internal
Internal
Internal
Frequency
50/60Hz
AC Voltage
100~240V
Maximum Power Rating
145W
430W
226W
424W
215W
17W
22W
Cooling
Certifications
EN 60950-1
EN 62368- 1
EMC
EN 300 386
Emissions
EN 55032, EN55035
EN 61000-4-2
Radiated
EN 61000-4-3
EFT/Burst
EN 61000-4-4
Surge
EN 61000-4-5
Conducted
EN 61000-4-6
EN 61000-4-8
EN 61000-4-11
Harmonics
EN 61000-3-2
Flicker
EN 61000-3-3
EEE
-5 ℃ ~ 55 ℃
-40 ℃ ~ 70 ℃
Opertaing Humidity
10%~90% RH
5%~95% RH
-50m ~ 5000m
Warranty
Package Contents
Power Cord
Mounting Kit
Quick Start Guide
Performance
20Gbps
56Gbps
56Gbps
12.8Gbps
12.8Gbps
40Gbps
56Gbps
Forwarding Rate
15Mpps
42Mpps
42Mpps
9.6Mpps
9.6Mpps
30Mpps
42Mpps
L2 Switching
MAC Table Size
8K
8K
8K
8K
8K
8K
8K
STP
RSTP
MSTP
✓(63 instances)
Port Grouping
IEEE802.1Q
IGMP Snooping
✓(v1/v2/v3)
Jumbo Frame
9KB
L3
IPv4 Routing
Static/RIP (in future release)
IPv6 Routing
Static/RIPng (in future release)
DHCP Client
SSH
SSL
Storm Suppression
Port Protection
Web User Interface
HTTP/HTTPS
Ruijie Cloud Management
RG-SNC Management
✓(Telnet/Console)
SNMP
Smart+ for CCTV
✓(Auto Smart Deployment/Remote Reboot Helper)
n/a
SYSLOG
Public MIBs
Private MIBs
RMON
✓(1/2/3/9)
Firmware Upgrade
Smart Managed Switch, 24 10/100BASE-T ports, 2 10/100/1000BASE-T ports, 2 1000M SFP ports, AC power supply, support PoE/ PoE+, PoE power budget: 370W
Smart Managed Switch, 24 10/100BASE-T ports, 2 10/100/1000BASE-T ports, 2 1000M SFP ports, AC power supply, support PoE/ PoE+, PoE power budget: 185W
Smart Managed Switch, 26 10/100/1000BASE-T ports, 2 1000M SFP ports, AC power supply, support PoE/ PoE+, PoE power budget: 370W
Smart Managed Switch, 26 10/100/1000BASE-T ports, 2 1000M SFP ports, AC power supply, support PoE/ PoE+, PoE power budget: 185W
Smart Managed Switch, 9 10/100/1000BASE-T ports, 1 1000M SFP ports, AC power supply, support PoE/ PoE+, PoE power budget: 125W
RG-S1920-18GT2SFP
Smart Managed Switch, 18 10/100/1000BASE-T ports, 2 1000M SFP ports, AC power supply
Smart Managed Switch, 24 10/100/1000BASE-T ports, 4 1000M SFP ports (With 2 combo ports), AC power supply
Ruijie Networks
About Cookies on this site
