Home> Products> Switches > Small Business Switches>
XS-S1960-H Series
XS-S1960 Switch Series is the newest access switch series for SMB market. XS-S1960-H Series Switches are fixed-configuration, Gigabit Ethernet switches that provide enterprise-class access switching for branch offices, the switches are managed switches offer advanced Layer 2 and basic Layer 3 features as well as High-power PoE Technology (IEEE 802.3bt). The switches adopt new web interface and can be managed at the free Ruijie Cloud platform, provides easy device onboarding, configuration, monitoring, and troubleshooting.
Feature highlights of XS-S1960-H Switch Series:
●Smart web and managed at Ruijie Cloud
●PoE+ support with up to 370W power budget and up to 60W by a single port
●Delivers enhanced network security, network reliability
●Design for Durability
More+
The XS-S1960-H Series supports abundant features such as SNMP V1/V2/V3, RMON, Syslog, and logs and configuration backup using USB for routine diagnosis and maintenance. Administrators can use a wide variety of methods for easier management and such include CLI, web management, CWMP(TR069), etc. With a friendly browser UI, administrators can do most of their job, such as performance monitoring, configuration.
The XS-S1960-H Series fully supports Ruijie Cloud which is a cloud-based service that help user manage and control devices and networks. It can monitor the network and configure or remote control devices.
The XS-S1960-H Series effectively prevents and controls virus spread and hacker attacks with various inherent mechanisms such as anti-Dos attacks, hacker IP scanning, illegal ARP packets checking and multiple hardware ACL policies.
●CPP can effectively prevent malicious attacks in the network and provide a clean environment for legitimate protocol packets.
●CPP is enabled by default. It provides protection during the entire operation of switches.
CPP protects the CPU by using the standard QoS DiffServ model
●IP/MAC binding: Implement flexible binding of a port or the system to the IP address and MAC address of users, strictly limiting user access on a port or in the entire system.
●DHCP snooping: Allow DHCP responses from trusted ports only; based on DHCP listening and by monitoring ARP dynamically and checking the user IP address, directly discard illegal packets inconsistent with binding entries to effectively prevents ARP frauds and source IP address frauds.
●Secure Shell and SNMPv3: Secure Shell (SSH) and Simple Network Management Protocol v3 (SNMPv3) cryptographic network protocol ensure the security of management information. Provides services such as multi-element binding, port security, time-based ACL and bandwidth rate limiting to block unauthorized users.
●NFPP: Network Foundation Protection Policy (NFPP) provides guards for switches. Malicious attacks are always found in the network environment. These attacks bring heavy burdens to switches, resulting in high CPU usage and operational troubles. These attacks are as follows:
○Denial of Service (DoS) attacks may consume lots of memory, entries, or other resources of a switch, which will cause system service termination.
○Massive attack traffic is directed to the CPU, occupying the entire bandwidth of the CPU. In this case, normal protocol traffic and management traffic cannot be processed by the CPU, causing protocol flapping or management failure. The forwarding in the data plane will also be affected and the entire network will become abnormal.
○A great number of attack packets directed to the CPU consume massive CPU resources, making the CPU highly loaded and thereby influencing device management and performance.
●Easy management: Administrators can centrally manage all the devices at the same time. It is no longer necessary to configure and manage the switches one by one.
Simplified Network Topology Enabled by VSU
The XS-S1960-H Series supports spanning tree protocols of 802.1d, 802.1w, and 802.1s to ensure rapid convergence, improves fault tolerance capabilities, ensures stable running of networks and load balancing of links, and provides redundant links.
In the corrosive gas, high humidity environment, electronic products will accelerate corrosion, reliability and lifetime will be shortened, However, deployment environments of access switch are different, there may be lack of temperature and humidity regulation and close to the source of pollution or the sea. Through the design for durability, such as conformal coating, XS-S1960-H Switch Series can operate stably in a variety of deployment environments.
The PCBA of XS-S1960-24GT4SFP-UP-H and XS-S1960-48GT4SFP-H have conformal coating with excellent insulation and protection against moisture, dust, corrosion, mildew and salt spray to enhance environmental adaptability.
New Option for High Power IP Devices
There used to be only two options available for remote power supply scenarios, namely PoE and PoE+ standards. Both XS-S1960-10GT2SFP-H and XS-S1960-24GT4SFP-UP-H can support PoE and PoE+. But PoE standard would fail to meet the needs if more than 30W power is required. Instead, electrical wiring or even high power has to be deployed. Such implementation gives an enormous burden to total investment cost, completion schedule, post-sale maintenance, as well as installation safety. XS-S1960-24GT4SFP-UP-H pushes the frontier with leading IEEE802.3bt standard, delivering 60W power output per port. It guarantees the best security, efficiency, stability and energy-saving experiences.
PoE/PoE+ Support
XS-S1960-24GT4SFP-H
XS-S1960-48GT4SFP-H
XS-S1960-10GT2SFP-P-H
24 10/100/1000BASE-T ports
4 1G SFP ports (non-combo)
48 10/100/1000BASE-T ports
24 10/100/1000BASE-T ports (PoE/PoE+) and 4 Gigabit SFP ports (non-combo) uplink, Port 1-4 for HPoE
10 10/100/1000BASE-T ports, 2 100/1000BASE-X SFP ports (non-combo), Port 1-8 support PoE/PoE+
Fan Slots
Fixed
Fixed
Management Ports
56Gbps
104Gbps
128Gbps
24Gbps
42Mpps
78Mpps
96Mpps
18Mpps
Up to 16K
Routing Entries
IP Host Entries
(IPv4/IPv6)
Up to 1,500
Up to 750
AP, LACP, Flow balance
Up to 128
IGMP v1/v2 snooping, IGMP SGVL/IVGL, IGMP filter, IGMP fast leave
MAC, EEE, ARP, VLAN, QinQ, Link aggregation, Mirroring, STP, RSTP, MSTP, Broadcast storm control, IGMP v1/v2 snooping, IGMP SGVL/IVGL, IGMP filter, IGMP fast leave, DHCP, Jumbo frame, RLDP, LLDP, REUP, G.8032 ERPS, Layer 2 protocol tunnel
Layer 3 Features
IPv4 static routing, IPv6 static routing, RIP, RIPng, ARP proxy, Neighbor Discovery
Layer 3 Protocols (IPv4)
Static routing, RIP, RIPng
Static routing, RIPng
Support (Up to 4 stack members)
NA
RAS
VSU (virtualization technology for virtualizing multiple devices into 1); GR for RIP; ERPS (G.8032); REUP dual-link fast switching technology; RLDP (Rapid Link Detection Protocol)
RAS GR for RIP ERPS (G.8032); REUP dual-link fast switching technology; RLDP (Rapid Link Detection Protocol)
(W x D x H) (mm)
440 × 268 × 44.5
440 × 268 × 44.5
440×260×44
340 × 260 × 44
≤3.5kg
≤4kg
TBC
<2.5kg
>200K hours
Lightning Protection
6KV
Frequency: 50 to 60Hz
PoE Power Budget
NA
370W
125W
≤24W
≤40W
≤460W
≤165W
Storage humidity: 5% to 95%RH
IEC 60950-1,EN60960-1
Emission Standards
FCC Part 15, Subpart B
ANSI-C63.4-2014
This networking topology enables XS-S1960-H series to cooperate with convergence switches (eg.RG-S5750-H) in an entire building and core switches (eg.RG-S86E series) in the core area to provide gigabit services for desktops.
Network Topology Using XS-S1960-H Switch Series
XS-S1960-24GT4SFP-H
XS-S1960-48GT4SFP-H
10 10/100/1000BASE-T Ports, 2 100/1000BASE-X SFP Ports (non-combo), Port 1-8 support PoE/PoE+
  • Sales Enquiry
